Found a radio
I've been wanting a vintage radio but they can be understably expensive. I came across this case for $20 and really couldn't say no. By no means am I any level of expert on any brand of vintage radio whatsoever. just like the look of them. everything in my home is vintage and it was kind of the last thing I was missing.
If anyone knows the year and model or any information about this , I'd appreciate it. there's a small white info sticker on the inside that said philco so I knew that much (: he told me he got it in the 70s and it was old then so he thought maybe 50s.
I would like to find knobs at least. Any help is appreciated
Hi and welcome
For starters look in Phorum gallery
Or post a pic of front and back
Sam
I've added an attachment several times, it's not posting it. I can't do anything about that I guess.
Information about posting pictures.. ...https://www.philcoradio.com/phorum/showt...p?tid=4407
https://www.philcoradio.com/phorum/showt...p?tid=4371
]I use Tumblr for posting my pictures. It also works well for re-posting here.
Shucks, . . . you us on pins and needles!   Icon_e_surprised
Welcome.
