Threads: 49
City: Allendale, MI
(This post was last modified: 09-08-2019, 01:00 AM by rfeenstra.)
Threads: 5
City: Woodland, CA.
Now THATS what i call "GUTTED!!"
Thats about what it would look like if Philco sold it "Heathkit style".
Looks like Klinger got ahold of it..
Modified Col. Potter : "Care to explain the explosion from the Philco plant?"
I bet the end result will be STUNNING!!
(This post was last modified: 09-08-2019, 01:24 AM by Stall-U-Rated.)
Threads: 214
City: Seattle
State, Province, Country: WA
Wow - respect for the time and effort you take!
Will be following along for sure.
Threads: 569
Wow......
Now let's imagine this was a .... an old car and it needed brake pads changed. And 5 quarts of oil.
No, seriously.....my respect.
Threads: 5
City: Woodland, CA.
Just a little more and...... CHROME THAT SUKKA!!!
Threads: 569
First I thought you meant Russian "suka" that means "CENSORED".
Then I realized it is "sucker".
Either one works
Threads: 49
City: Allendale, MI
Chrome? It's not an E. H. Scott! But hey, it's a challenge to take her down to its beginning and resurrect her. I think its fun, in my own warped mind.
Some progress:
The hacked up shields:
Shields re-riveted in place, not perfect but ok given the damage:
Filaments rewired:
You can see the discoloration in the antenna coil shield from the fried antenna coil.
(This post was last modified: 09-08-2019, 11:29 PM by rfeenstra.)
Threads: 49
City: Allendale, MI
You can see the capacitor can in the background in one of the previous post's pics. What was the plating on this and on the tube shields? I'm thinking it was tin and am thinking of playing with tin plating to bring them back to their original glory. Am I wrong? Maybe it was nickel?
Threads: 49
City: Allendale, MI
I've been looking for info on the antenna coil, part number 32-1182. I suspect that the primary that was fried by lightning was a coil that was inside the form for the rest of the coil. Does anyone have any info on this coil? There is enough of the original wire to measure the diameter to approximate the AWG. Given the known resistance, I can estimate the length. But, I'm not sure how it was wound. Any info would help. From the 1 inch of wire that was left, it appeared to be cloth covered. That would lead me to believe it was a separate coil inside the coil form as I have seen in many Philco coils.
Threads: 49
City: Allendale, MI
One more question: the wire was definitely cloth covered and measures to be equivalent to about 35 AWG. This give a resistance of about .33 ohms per foot. The schematic from riders says this coil is 43 ohms. That would be about 130 feet of wire. That seems way high to my non EE mind. If it were actually 4.3 ohms (I cannot see a decimal point on the schematic - all other fractional ohm coils have a clear decimal point), that would mean about 13 feet of wire, which seems too little to me. Is 130 feet reasonable for a bobbin wound coil on the inside of the form? I've never unwound one, so I don't know!
Rob
The tube shields were originally plated with tin, yes. Not certain about the capacitor can but it was probably plated with tin as well.
Threads: 49
City: Allendale, MI
Thanks Ron. I may look into what it takes to do tin plating. I did some cadmium plating on airplane parts a few years ago using the brush plating technique. It was not difficult.
Threads: 44
City: Menlo Park
State, Province, Country: CA
In the box of "junk" 16 parts I bought, there is an antenna coil - and some better condition shields Let me search it all out. I believe the coil got a little damaged on it's way to me. Parts are yours if you would like them - just let me know. I'll try and post pictures.
Cheers
Ed
Threads: 49
City: Allendale, MI
Yes! Yes! Yes! Thank you! PM me when you find the parts. There are 2 antenna coils in the 16B I need the BC band and Police band coil It is #9 on the schematic and is in the shield that is closest to the capacitor can. It has 6 terminals (#8 on the schematic has 7).
(This post was last modified: 09-09-2019, 11:56 AM by rfeenstra.)
Threads: 44
City: Menlo Park
Thanks for the details - now I know what to look for. I know I have all the parts, but the windings themselves are damaged, and will need to be rewound. I wish people would learn to pack things with more care... I'll look in the box tonight and will send a PM with full details as requested,
Cheers
Ed
Users browsing this thread: 18 Guest(s)
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
There are currently 4380 online users. [Complete List] » 3 Member(s) | 4377 Guest(s)
