Threads: 49
City: Allendale, MI
All the good radio shows are late at night. Like Ziggy's Midnight Blue, conspiracy theory shows, etc. I like working at night as it's quiet in the house with no phone interruptions. Once I focus in on a project, I tend to loose track of time. Before I know it, it's 2 or 3 am. The problem is, I have a hard time sleeping in in the morning. Eventually I have to play catch-up.
Threads: 44
City: Menlo Park
State, Province, Country: CA
That looks fabulous Rob. I'm glad the coil was helpful - was it tricky to reconnect the fine wires from the internal bobbin?
Even without an RF stage, these radios impress me. In fact, one of my favourite modern communications receiver brands chose to go straight in to the mixer stage (via bandpass selection) and still achieved microvolt sensitivity. If you can hear the atmospheric noise jump when the antenna is connected, generally you have enough sensitivity.
Threads: 49
City: Allendale, MI
Not really difficult. I had to extend one of the wires from the coil by about an inch. I used 35 AWG magnet wire. The hardest part is stripping the old enamel off from the original wire. It doesn't strip with just the heat of the solder iron like the new wire does. None the less, it wasn't difficult and it works great. I'm surprised at its sensitivity without an RF amp, as you seem to be. I was also surprised at how close bands 4 and 5 turned out to be without separate compensators for heach band. All and all, very pleased and have been listening to it in the shop for the last couple of days as I change out 100's of tiny pots on some Allen Organ tone boards from a large custom organ. I slowly go insane with the tedium!
I may tackle the cabinet before I do some of the others that are waiting. The radio sounds so much better with the speaker in the cabinet and I kind of like this radio!
Threads: 49
City: Allendale, MI
Decided to try my hand at molding resistors. They kind of look original...if you don't look to closely.
Threads: 569
Unless one is an expert and uses a magnifying glass......great job! Looks as original as ever. (Well, Russ or Steve might notice something  but not me )
Have you used plastic or epoxy/filler mold?
Fine job, Rob. Fine job.
Threads: 49
City: Allendale, MI
I made the mold in epoxy resin and the resistors are epoxy putty. I won't do it that way again. The epoxy mold makes it too difficult to get the original parts out even with a lot of mold release. I'll buy some of the silicone rubber molding compound that Russ uses and recommends. A tiny bit of flexibility would help greatly in removing parts.
Only the 3 larger ones are redone. The rest are original with a hidden, parallel resistor underneath.
(This post was last modified: 10-01-2019, 10:56 AM by rfeenstra.)
Threads: 569
That's what I recently started doing: hide a smaller resistor to parallel the original to bring the resistance within tolerance limits.
Threads: 49
City: Allendale, MI
That works for the smaller dogbones. They all seem to go up in value. As you mentioned before, the large ones seem to go down in value. Replacement is the only reasonable way to get it into spec. I have tried to hide a series resistor but it doesn't work well as far as the installation is concerned. I did do that on my 45C. Probably won't again now that I know I can do this.
Threads: 569
ON my recently finished 45C I did both. Yes, with the large resistors I had to use the modern types as they went down quite a bit. I could serialize of course but then serialization does not lend itself to hiding as well as paralleling does.
Threads: 49
City: Allendale, MI
I'm looking to finish this electronic restoration up. There were 2 labels on the back of the radio that were gone when I got the radio. I presume the area circled in blue is where the gold, model label was located. What might have been on the capacitor can? Did Philco put something there, or was it, perhaps, another sticker from the repair company in maine? Also, there was something on the top of the capacitor can. It looked like it may have been another sticker. Perhaps a part number sticker? Thanks!
(This post was last modified: 10-02-2019, 12:16 PM by rfeenstra.)
Threads: 19
City: The Motor City,Detroit MI
Mine has no sticker, maybe there is a ghost of a sticker.
(This post was last modified: 10-02-2019, 12:18 PM by Kestas.)
Threads: 49
City: Allendale, MI
Thank you. I suspect it was from the repair shop.
Threads: 49
City: Allendale, MI
I decided to complete this radio so I started the refinishing process. I could start a thread in the finish section but it made sense to me to keep it all together.
The cabinet has been stripped and now has 2 coats of Mohawk EZ Vinyl sealer. Next will be filler, than sanding sealer and finally, semi gloss lacquer.
Questions on toner colors. I'll use walnut brown grain filler even though the wood is, I believe, some form of mahogany. You can see how dark the finish was under the escutcheon. What toner would you recommend for the inset?
The surrounding wood was fairly red. Toner recommendation? The trim pieces were not a lot darker than the surrounding wood. I may darken it ever so slightly more than the surrounding wood to help hide the end grain at the top and the joint.
The sides were quite dark and red. A suggestion for toner?
Thank you in advance for your recommendations!
Threads: 268
I tend to stay away from the mahogany to me it too red and you loose the yellow quickly. If you like it just a little on the caramel side of things I stick w/ the walnut and sometimes I add a little yellow by using pine ( I think look @ the color chart ).
ymmv
Users browsing this thread: 20 Guest(s)
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
There are currently 4372 online users. [Complete List] » 3 Member(s) | 4369 Guest(s)
