Found—Model 40-150 in Chinese black lacquer highboy cabinet
Threads: 5
City: Boston
State, Province, Country: MA
Threads: 271
City: Wilsonville
State, Province, Country: OR
Welcome to the Phorum!
Its not a Philco cabinet, that's for sure. I would suspect there are not many other cabinets like it.
Threads: 5
City: Boston
![10-24-2019, 02:59 PM](attachment.php?aid=20501)
Thanks, Bob. I'll post pics as it comes back together. Cabinet is mahogany with black lacquer. 3 legs were snapped at the top, but should be repairable. I'm looking forward to it, but more so to the radio restoration. I have a number of radios waiting for me to learn more before I start, including a 1930 Kellogg Model 524 that will be last on the list. This is a shot of the back panel to the cabinet.
Threads: 28
City: Wellborn Florida
Some info from Beitmans
Threads: 5
City: Boston
Threads: 562
Whatever it is, it is an uncommon radio and didn't become any worse from being put in this cabinet.
Threads: 5
City: Boston
Threads: 69
City: Kansas city, MO.
Hello. That looks like the part # 38-9935 of the cardboard antenna back. I have a model 40-150 Philco. It is in a wood slant front cabinet.
Restored the chassis 3yrs ago. I think they have the rubber wire that is usually rotten and falling apart. Good luck with the restoration plenty help here if you need it.
Threads: 5
City: Boston
Thanks, Mike. Looking forward to it!
Threads: 310
City: Kings Park NY
FANTASTIC!
AC: 4 DC: 1
Threads: 5
City: Boston
Threads: 310
City: Kings Park NY
Momma LIKE!
AC: 4 DC: 1
Threads: 69
Good job getting it back up on its feet.
Threads: 4
City: Monteith, Ontario CA
I wonder if the antiquity here is NOT the radio as much as the cabinet. Maybe you should take your photos to an antique furniture specialist and see if the cabinet is rare and worth donating to a museum or ... what it's history might be?
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
There are currently 10244 online users. [Complete List] » 2 Member(s) | 10242 Guest(s)
