Ron's RCA Victor T8-14
#31
Phlogiston Wrote:On those filter caps, I usually drill a small hole in the metal stud its self. It is easier than drilling the Bakelite.
Oh, I do as well. But please go back and examine the photos again. The Solar cap is constructed differently from an original stud mounting electrolytic - the entire base, including the threads, is Bakelite. So it called for some rethinking since I did not have another original type stud mounting electrolytic (with insulating washers) in my stash o' stuff.
And if you mean the aluminum rivets that hold the solder terminals in place (upon rethinking, I suspect this is what you meant), I don't have a drill press so I can't always drill through those rivets without causing trouble. My method worked, though - that's all that matters to me. Icon_smile
Yes, the rivets. I use a hand drill (cordless) but you must use some never-seize or similar lube. I also use this technique on newer multi section caps, like the ones in the Sabas.
That does make sense.
Oops! Icon_redface
I realized that I had forgotten to restuff C32, the .01 uF cap in a metal case. So this evening, I took care of that. It was very difficult to get the metal end caps off, but patience and persistence finally paid off. The new cap is sealed in hot glue inside the metal case.
Hopefully tomorrow evening, I'll have time to attach an AC cord and test the tubes.
Tonight, I attached a new cloth covered line cord and found a suitable AC plug in the parts bin.
I also installed two new LED (#46 equivalent) lamps.
I applied power to the chassis with all tubes removed. The dial lit up. No sizzling from the power transformer, or any other unexpected surprises.
Next step was to test the tubes.
When I was finished, I needed four tubes - 6F5, 6J7, 6K7, and 6L7.
I have an RCA 10K1 Magic Brain chassis I had purchased recently. Anyway, it had the tubes I needed - all were original RCA metal - and all were good. Icon_thumbup So they went into the T8-14. I'll buy replacements later and put these back into the 10K1 chassis at that time.
Hopefully tomorrow evening...first power up with tubes and speaker.
Ron
 I never was a fan of metal tubes, but through the years I have accumulated many. I can dig through the box I have of them and find the ones you need.
I can then send them to you. LMK
#37
Well, I opened my mouth and firmly inserted my foot.
I don't have a 6J7. Icon_sad
Sorry
#38
Ed
That's okay. I appreciate your looking. Icon_thumbup
I'll send you a PM later regarding other metal tubes.
I never cared much for metal tubes either. But now that I'm restoring some RCA sets which originally used them, I'd like for my RCA sets to have them if possible just for the sake of originality.
I am always on the lookout for the early metal tubes - with the bump. Almost all of the big manufactures, less Philco, used them in 1935. Many quit in 1936. The earliest ones showed up in 1932. They had stamped labels on the upper tube body until about 1936. I have found most metal tubes (after 1934) to be equal or superior to glass, if for no other reason, shielding.
" . . . opened my mouth and firmly inserted my foot."
Icon_lol
#41
The moment of truth.
I attached the speaker from my RCA T7-5 only because I was too lazy to detach the T8-14's speaker from its cabinet. (No, I have not yet completed the T7-5. The cabinet needs to be rubbed down, I need to decide which of a few patterns of grille cloth I have here to put into it, and it needs a new dial cover.)
I plugged the T8-14 into my Variac, plugged the Variac into the power strip. Turned on both radio and Variac. Slowly brought up the voltage on the Variac...
and once I reached 110 volts AC...
[Video: https://youtu.be/4sKl5bM2R5M]
It's Alive! Icon_biggrin
The video shows me tuning the AM band (Band A), the 49 and 60 meter portions of Band B, and part of Band C so it is a much longer video than I normally post (about 5-1/2 minutes).
The radio badly needs an alignment. One of the first stations I picked up was WJR, Detroit. The trouble is, WJR broadcasts on 760 kc and the T8-14 is receiving it at 63 on the dial. In the video, you will notice that the volume of stations increases considerably above 1000 kc.
Well...probably Friday late afternoon/evening sometime Saturday, I'll do the alignment. This will be my first real trial of my "new" B+K-Precision 4040 signal generator. In preparation for this, tomorrow night I'll wind the coupling coil suggested by John Bartley in my signal generator thread.
Edit: Well, I had better get that new dial scale cut out, drilled, and installed before I attempt an alignment! So the actual alignment may not happen until Saturday.
So I spent my Halloween doing some work to my T8-14.
I began by winding a 100 turn coil onto a toilet paper roll in preparation for giving this set an alignment. The plan is to connect the signal generator to the coil, and then wind a few turns of wire around that winding to couple to the radio.
The next job was to remove the old, worn out dial scale.
At first I thought the pointer was held in place by a tiny screw in its center. It certainly appeared as such. But after my tiniest screwdriver would not budge the "screw", I did a quick web search. I found that that isn't a screw at all but merely part of the slotted end of the shaft to which the dial pointer is fastened - it is simply pressed on. So I removed it by carefully pulling it off with a pair of needle nose pliers. Then, after removal of the four push pins (for lack of a better term) which held the dial scale in place, it looked as shown in the photo above.
And then, it was time to cut out the new dial scale. Yes, the dial scale I bought was uncut and undrilled. The plastic is very thick and hard also, and was quite hard to cut. But I finally managed to get the job done. Drilling holes was the easy part. Finally, I attached it to the dial face with pop rivets.
Here is how it looks now.
The original dial did not have the 0 to 90 scale around the perimeter of the dial. But the frequencies are the same, so it works for me. I have since learned this is actually the proper scale for a T10-1 or C8-15. Oh well. As I said, the frequencies are exactly the same.
After I took the photo, I noticed that I didn't get all of the dust off the dial scale left from drilling the holes. That was quickly taken care of with a tissue.
I pulled the rectifier tube, plugged the radio in, and turned it on just to see the dial illuminated.
The photo makes the areas where the dial lamps are located look much "hotter" than they really are. Blame my cellphone camera.
So now it is ready for the alignment which is to come tomorrow evening or Saturday.
Ron, the scale on my T8-18 was held on by the same kind of little push pin things. I had trouble removing them too. When I put it back I used little 4-40 pan head screws, lock washers, and nuts. They worked fine, and will allow easy removal in the future should it ever be needed.
#44
Epilog
I aligned the T8-14 late this afternoon using my "new" (to me) B+K - Precision 4040 function generator. In all, it took about 45 minutes. I went over the AM band multiple times since the low end was so far off. And then on band C, I had some trouble finding the fundamental at 18 mc but I finally did so after some tweaking and aligned it properly at 18 mc per the instructions.
I already knew the AM band's alignment was WAY off on the low end of the band. Alignment benefited the IF chain as well as all three bands.
I spent some time listening on all three bands, then stopped for dinner. Afterwards, I put the chassis back in its cabinet and shot the following video. You will notice now that not only are stations coming in close if not right on where they should be, but the low end of the AM band is now just as loud as the high end. And that is how it should be.
[Video: https://youtu.be/0zTt0uEKpvg]
And...that is it for this RCA Victor T8-14. The chassis is complete, aligned, and plays very well on all three bands.
Very Nice Workmanship,,,Great Job Ron,,,,well Explained,, and greatly detailed,,,,,
Hi Howard, if memory serves, and many times it doesn’t, I vaguely remember working on a Philco that had that pin you hav...462ron — 09:00 AM
Gloritone 27 Radio
Hello John, Thanks for the information and Arran I have heard of Wells Gardner and I have heard of Apex but I did not ...radiorich — 08:17 AM
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
There are currently 2435 online users. [Complete List]
» 3 Member(s) | 2432 Guest(s)
