Jackson Bell model 68 Tulip
Threads: 9
City: St. Petersburg, Fl.
Didn't know where else to go here.
I need help. I need a paper schematic, a good picture of original knobs, and, a rebuildable speaker for this set. It uses a Magnavox model 138 8" speaker. What can anyone tell me about this set, and, can anyone help me get parts for it?
I really want to restore it.
What year was this set made, and, what is the quality of this 8 tube radio?
I had replaced fried power transformer in it years ago, re capped it, and, put a temporary spkr. on it.
It would only play one station very weakly when I put my hand on secondary coil of first RF. And, that, same station all the way accross the dial.
What could be wrong?
Thanks.
Bill Cahill
"If it lights in the dark and leaves you with a warm glow it's tubes."
"Honey, did you warm the baby bottle on my 75 watt hi-fi again?"
"I left it somewhere, but, where?"
Threads: 8
City: Lexington, SC
Schematic emailed.
Hearing only one station generally means the local oscillator is not running. A strong nearby station is able to force its way in enough to be heard. Richard
Threads: 17
City: Yorkville IL
I'll post this link, I'm sure you've already looked there, but it does show the knobs.
http://www.radiomuseum.org/r/jackson_be_68_2.
Glenn
Happily back in Illinois..not.
Threads: 9
Please forgive my lack of knowledge. I am familiar with I F circuits, but, Haven't had enough experience on RF sets. Didn't know they used an oscilator on rf sets.
Thanks.
Got e mail, and, schematic. Many thanks.
Bill Cahill
There is no local oscillator in this set. It's a TRF, not a superheterodyne.
I have no idea when it was made, but it seems to be nicer than a lot of TRF sets of the late twenties/very early thirties...three stages of RF amplification, and push-pull 45 outputs.
I don't see much in the way of components between RF stages. RF coils, the 0.25 uF cathode bypass cap that is common to all of the RF amplifier tubes, resistors in the front end and voltage divider network, tubes...any of these could be causing the problem. Also a bad field coil, or filter choke. Check the voltages. You are lucky in that Rider's gives the voltages. A lot of the schematics for smaller companies such as Jackson-Bell didn't even give component values, let alone socket voltages.
Threads: 9
Actually, it's 4 rf stages. The radio dates to 1931.
It was a well made set. I'm missing the spkr. Made some jury rigs to try set.
Bill Cahill
No, Bill, it has three RF amplifier stages. The fourth "stage" is the detector circuit.
Threads: 9
![Icon_redface Icon_redface](https://philcoradio.com/phorum/images/smilies/icon_redface.gif) Thanks, Ron. I thought this one had a seperate detector. On the 1928 Edisons with 3 rf tubes, they used part of the 27 as the detector.
I have to familiarize myself with this schematic.
Oh, by the way. One of the big 3 knob dealers contacted me the other day. She offered me a set of bakelite knobs she says are for my set. The only difference is the picture of another set I saw shows a 3 step knob, and, these are two steps. Otherwise, they look exactly like them. Any comments here?
My friend, Mr. Detrola from ARF says since he's seen variations of original knobs on different sets produced by this companny, that it's very plausable, in his view, that these are yet another variation.
Bill Cahill
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
There are currently 5637 online users. [Complete List] » 1 Member(s) | 5636 Guest(s)
