  • 1 Vote(s) - 4 Average
Made A Few Dogbone Resistors
I've spent the last couple of weeks making dogbone resistors. I've been selling a few and was running low on some. The last two days I have been painting them. Should be good for a year or two.
[Image: https://live.staticflickr.com/65535/4913...1b79_z.jpg]Dogbone Resistors by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4913...ac58_z.jpg]Dogbone Resistors by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4913...0b0c_z.jpg]Dogbone Resistors by Steve Davis, on Flickr
M R Radios   C M Tubes
Very nice, but your wife wants her clotheslines back!! Take care, Gary
WOW,
A few? Icon_lol
Looking fab..
Kirk
Very impressive!
Philco 91 Tuning Condenser
There are currently 9972 online users. [Complete List]
» 1 Member(s) | 9971 Guest(s)
