The Philco i bought.
Smile
Here is the 38-62 i bought from ebay he accepted my offer of 100.00 and i got it for 124 and change that includes shipping the package shows to be in Pennsylvania according to the tracking number and should be here Saturday maybe sooner who knows. I picked it because the photo finish is nice and the chassis looks to lack any corrosion from the back the top needs redone but i can live with that.
He said it hums so that at least tells me that there is not any serious problems i hope well enough flapping my mouth here it is coming from Bel Air, MD where ever that is.
https://www.ebay.com/itm/ART-DECO-PHILCO...true&rt=nc
Merry Christmas. Happy Hanuka.
Beautiful,
I did one a few years ago. The cabinet was almost as bad but like you, the photofinish was great.
Good find!
Icon_smile
Philco 91 Tuning Condenser
There are currently 8961 online users. [Complete List]
» 2 Member(s) | 8959 Guest(s)
