Threads: 3
City: Salisbury
State, Province, Country: NC
Thanks for the add! I hope to learn more from the experts here. I have recapped my 41-608 (thanks for the help on another thread on wiring can #21) but still don't have any radio stations what so ever. There is still a slight hum in the sound but now the phonograph is at least audible. Are there any hidden caps I could have missed? Any help will be appreciated. Again thanks
Threads: 569
Recap is only the first step.
You have to attempt to align the radio, and if you cannot pass the signal through and you are sure your tubes are good, start looking for open RF doils.
Threads: 268
Hi Derek and welcome,
I would break out the signal generator and set it up to produce a modulated 455KC signal. Connect the output of the generator to terminal strip on the back of the chassis terminals 2 (signal side of the generator) and 3 (to the gnd side of the generator). If the IF and det stages are working you should hear If you the modulating tone. At this point you can adjust #27a, 27B and 30. If you are using a old 50's service grade generator double check the calibration . Turn the set on in the dark and make sure that all the tube are lit, the loctals can be a little hard to see into.
GL.
Threads: 3
City: Salisbury
I don't have a signal generator so it will have to go to a shop to be adjusted. I found the hum I connected the negative side of 21B to the wrong terminal now the phonograph sounds great! Thanks for the help
Threads: 30
City: Wellborn Florida
Found some info from Beitmans.
Threads: 569
Derek,
A SG could be (if you don't want to invest much) a $20 job like a Leader or such, a 1-tuber. For a beginner and troubleshooting quite enough.
Not sure what shop it is but if it is a commercial place, the charge will be such that you could buy 3 to 5 of these.
If you are serious about radios, at least get that.
Threads: 3
City: Salisbury
Didn't know they were that reasonable what would you suggest for someone that wouldn't be using one that much and would be simple for a beginner like me
Threads: 3
City: Salisbury
I just received my signal generator and connected the red lead to the number 2 terminal on the back of the radio and the black lead to the number 3 terminal. I then turned the dial all the way to the right. I switched both units on and hear no signal. What did I do wrong or what could be the problem.
Threads: 3
City: Salisbury
Threads: 3
City: Salisbury
Retryed again today on working radio and got my tone so generator works. Reconnected to philco and tone came through. Adjusted 27a 27b 30a and 40a by instructions on Rider pg&e 12-76. Still no signals. Operation 2 on Riders says to connect generator to "loop signal generator" and set generator to 1500 khz. Where is this located.
Threads: 268
What they are saying is to use a loop connected to the output of the generator placed near the ant loop of the radio. This loop on the generator would consist of about 20t of hook wire 1' in diameter.
Threads: 3
City: Salisbury
By hook wire do you mean picture hanging wire
Threads: 268
Sorry meant hookup wire.
Threads: 3
City: Salisbury
Don't want to sound bad but what is hookup wire?
Threads: 268
Just regular old wire. Plastic or enamel coated. Average gauge like 18 to 26 is good.
Users browsing this thread: 15 Guest(s)
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
There are currently 3387 online users. [Complete List] » 1 Member(s) | 3386 Guest(s)
