Philco 90 Restoration
Possible repairman's mistake it doesn't make since to put a .01 inline with the .25 .
Merry Christmas. Happy Hanuka.
OK, on to the condenser blocks, but first, a shameless plug. If you don't have these condenser tools, you really need to get a set, they make this job so much easier. A little twist of the cutter tool cuts the wires, heat the block and push the guts out with the punch tool. Then clean the terminals and install a new capacitor.
[Image: https://live.staticflickr.com/65535/4917...3092_k.jpg]Philco 90 Restoration by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4917...c908_k.jpg]Philco 90 Restoration by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4917...c563_k.jpg]Philco 90 Restoration by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4917...5843_k.jpg]Philco 90 Restoration by Steve Davis, on Flickr
This particular capacitor is .15uf connected in parallel with the filter choke, it will be omitted. I simply gutted it, cleaned and reinstalled the empty block.
 [Image: https://live.staticflickr.com/65535/4917...e75e_k.jpg]Philco 90 restoration by Steve Davis, on Flickr
M R Radios   C M Tubes
Steve nice tools i got some old wooden file handles around i could make a cheap and dirty copy been using a modified pin punch and hair dryer to get the tar out of these.
About half of the "Dogbone" resistors were out of tolerance, I went ahead and replaced all.
[Image: https://live.staticflickr.com/65535/4920...404d_k.jpg]Philco 90 Restoration by Steve Davis, on Flickr
The filter capacitors were aluminum can replacements from years ago. So, the next step is off to my storage area to find a couple of Mershons to restuff.
What came originally , filter capacitor-wise,  in this radio?  Would they have been those Mershon capacitors?...or something marked "Philco"?
Jake, originally, it would have had Mershon or Sprague.
Ok,...thanks.
...so is there a way I can determine if the 610 originally came with Sprague, Mershon, Solar capacitors,. . . or cans branded Philco ?
Looking through my "Someday Kit" I found a 70 chassis that had a nice pair of Mershons it wanted to donate.
[Image: https://live.staticflickr.com/65535/4920...a00f_k.jpg]100_0146 by Steve Davis, on Flickr
Now to get them apart without destroying them.
First, I cleaned and polished them. I taped one end to protect the can from being marked by the jaws of the lathe chuck. After polishing one end, I turned it around and finished polishing.
[Image: https://live.staticflickr.com/65535/4920...56c4_k.jpg]100_0149 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4920...b959_k.jpg]100_0150 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4920...b21e_k.jpg]100_0153 by Steve Davis, on Flickr
To open, I decided to grind the crimp on the bottom rather than removing the top, It just seemed to be a safer bet.
 [Image: https://live.staticflickr.com/65535/4920...1e09_k.jpg]100_0155 by Steve Davis, on Flickr
I'm using a 1/4 inch brass bolt for the terminal. Here I'm drilling the head of the bolt so I can solder in a number 12 buss wire.
[Image: https://live.staticflickr.com/65535/4920...e9e5_k.jpg]100_0164 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4920...07c9_k.jpg]100_0170 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4920...c7c2_k.jpg]100_0171 by Steve Davis, on Flickr
I'm using six 2.2uf 630v film capacitors.
[Image: https://live.staticflickr.com/65535/4920...24ef_k.jpg]100_0172 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4920...678b_k.jpg]100_0175 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4920...d106_k.jpg]100_0176 by Steve Davis, on Flickr
Steve those Mershons look great! I have a 70 with Mershons that I will get to in the future and would like to know if after polishing them, do you spray them with clear lacquer to keep them bright? Thanks.
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Ron, I was wondering the same thing. This morning, I look at them, they appear to already be tarnishing. I still have to stuff the second one after that, I think I will spray them.
If you've ever polished copper you'll find they need to be coated or they'll turn brown in no time.
I installed two 4.7uf film capacitors in the other can to be used as the input filter. I then sprayed a coat of lacquer on cans and installed them in the chassis.
[Image: https://live.staticflickr.com/65535/4921...b6bc_k.jpg]100_0192 by Steve Davis, on Flickr
After one more good looking over, I'm ready for the "Smoke Test". I hooked up the speaker and brought it up slowly.
[Image: https://live.staticflickr.com/65535/4921...9ba0_k.jpg]100_0194 by Steve Davis, on Flickr
Oh no, I have a problem! The screen grid on one of the 47s is glowing bright orange! I quickly turned the radio off. Now, this is what happens when you get old. I bought this speaker on eBay and for some reason, I forgot to test it! One half of the primary of the output transformer is open. The speaker is not correct for this chassis anyway. This one is for an early 90 but, there is almost no hope of finding a speaker for a late 90. I will probably wind up buying universal replacement transformer. So for now, I pulled the speaker out of my Philco 20 as it is the only P-P speaker that I have that has the correct field coil resistance. So I try again. Wow! Its talking! I'm surprised, I figured the alignment would be so far off (remember I had the tuning condenser completely apart)  that it wouldn't pick up anything but, I have three or four stations coming in weakly. Maybe tomorrow evening I will have time to do the alignment.
Hmmmm....those caps sure look nice!  What is that machine you did that on?...is that a lathe?  Icon_question
There are currently 3060 online users. [Complete List]
» 4 Member(s) | 3056 Guest(s)
AvatarAvatarAvatarAvatar
