1932 U. S. Gloritone Model 99A Cathedral Radio
Hello everyone, about 5 years ago I was given a 1932 U. S. Gloritone Model 99A Cathedral Radio that someone had restored electrically but then somehow destroyed the original Utah speaker and the original grille cloth by what appeared to of been grabbing the radio by the front of the cabinet and then having it slip out of their hands and their fingers went right through the speaker and grille cloth and absolutely destroyed it, plus the original finish on the cabinet was completely shot on it.
So over the course of about 5 years (yes it took me 5 years to finish restoring this radio) I repaired the tears in the original Utah speaker by using brown coffee filter paper and watered down Elmer's Glue and then I completely stripped the old finish off the cabinet of the radio and refinished with a couple of coats of Minwax #224 Special Walnut Stain followed up by 2 coats of Polyurathane with some light sanding with 220 grit sandpaper in between coats.
I think the finished product turned out pretty good for being my very first radio cabinet refinishing project.
Before and after pictures posted below.
More pics.
The first two pics are the before shots of the radio and the rest of the pictures are the after shots.
Pretty grill.
Not bad for that first restoration...better than I did. Icon_lol
Thanks, I'm glad you like it.
It was definitely a long time coming because it kept getting put on the back burner for 5 years because I would keep getting new projects to work on from other people (or I would buy something else to work on as well) that was easier to work on, plus by the time I would think about refinishing the radio it was too late and it would start getting too cold, so I finally got it done this past summer.
Very nice work!
Indeed. Thank you all. I'll remove and test the rest of the transistors. I'm trying to trace everything at the test p...R3Sons — 12:06 PM
Yes, if the speaker was disconnected or bad connections, it could cause high enough voltage spikes on the collector to k...462ron — 10:40 AM
42-345 Resistors
Good.morzh — 10:38 AM
I would check things around before simply replacing the transistor. Something killef it.morzh — 10:37 AM
÷1 to Sincere Richard. I use Mouser but either is the way to go. I'm sure the others, like justradios, are in the group...RodB — 10:24 AM
RS3, that output transistor X6…AR14, can be replaced with a GE-3 or ECG-121, probably others too. Ron462ron — 10:01 AM
Philco 7053
Thread moved to test equipment section. (I have not used one of these)klondike98 — 07:05 AM
Thank you Richard.R3Sons — 01:37 AM
R3Sons, I buy my resistors from either digi key or mouser ! Sincerely Richardradiorich — 01:28 AM
Replicating (dogbone) resistors what method have you used ?
Hello Guys, I can't wait to try printing some of these I might go ahead and order some from PCB way ! Sincerely Richardradiorich — 01:26 AM
There are currently 2868 online users. [Complete List]
» 1 Member(s) | 2867 Guest(s)
