Stewart Warner model 1845 tuner operation
Hello fella's,
Wondering if anyone can tell me how the manual/electric tuning control is supposed to work on this radio?
It is the R184 chassis, and it has a large brass outer portion which is pushed in for electric and pulled out for manual tuning.
But when you pull it out it ends up completely covering the inner 1/4 inch shaft that has the flat on it.
Hoping someone here has one and can fill me in on the operation of this control.
Looks like quite an elaborate mechanism.
murf
I have a Stewart Warner console  model  409 with 15 preset push buttons.
 If your chassis is similar, the instructions for setting up the preset might be the same.
    I think that the presets might be very close in operation.
     It took me a couple of years to get this information, but I could sent it to you if you like.
 It covers all the small adjustments,like how far apart certain contacts should be  ,etc, etc.
    Here is some information.
 Dan in Calgary
   Living in Calgary Alberta
Thank you Richard.R3Sons — 01:37 AM
R3Sons, I buy my resistors from either digi key or mouser ! Sincerely Richardradiorich — 01:28 AM
Replicating (dogbone) resistors what method have you used ?
Hello Guys, Ican't wait to try printing some of these I might go ahead and order some from PCB way ! Sincerely Richa...radiorich — 01:26 AM
Does anybody have a line on replacement resistors?R3Sons — 12:21 AM
42-345 Resistors
I replaced all the electrolytic capacitors. That big Philco 12uf 400V electrolytic Vienna sausage. is one I removed and ...proftrussell — 11:58 PM
Well...taht's a start.morzh — 10:15 PM
X6 is out. Only pulling 3mA now, 220mA with the light on. Test point 18 is 12.2 Test point 19 is 12.06R3Sons — 09:46 PM
Philco 7053
Any of you guys have and used this tester?Martinj — 09:27 PM
I would test all, but the X6 is the main suspect. The output is the autotransformer, and it also could potentially ha...morzh — 09:13 PM
Yes, I tested them out of the circuits. I posted my measurements where the first letter was red and the second was blac...R3Sons — 08:52 PM
