Source for non-spray-can toner?
Anyone know where I can get concentrated toner to be added to normal lacquer? I already have two reasonably nice compressed air sprayers. It seems a shame to have to use a rattle can for the toner application.
Try this. I'm planning on purchasing some of their dyes soon because I too have the spray equipment and it would be cheaper in the long run than rattle cans.
http://www.veneersupplies.com/categories...6__Stains/
Jay
Yep, TransTint is a good choice. Yes, it seems pricey but it only takes a few drops in your spray canister. You get a lot of mileage out of the 2 ounce vial.
Great! thanks. I'll order some up and experiment a bit (before hitting the radio...heh).
Audin,
I use Behlen brand stain, you can get it at Grizzly http://www.grizzly.com/products/searchre...hlen&new=1
M R Radios   C M Tubes
I have used Trans-Tint many times. Yes, a little goes a long way. Locally they are around $18 but you can get a bottle online for around $14.
You can also mix 2 tints together for a custom color.
The trouble with some satins is that once applied, you might not get as dark as you need. Second and third applications don't seem to make much difference. So, the toners are a good way to lay down extra color and build up your finish coat.
Please experiment before you do your set. Depending on the amount of tint, the thickness of the coat and how many passes you make all affect the degree of color.
Here's a partial color chart. Again, you can get darker if you need by adding more tint, or more coats.
[Image: http://www.highlandwoodworking.com/Produ...195707.jpg]
Philco 91 Restore Code ??
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 2357 online users. [Complete List]
» 3 Member(s) | 2354 Guest(s)
