Mystery
"Octals?"
Yes.... the larger glass tubes with the larger bases and up to 8 pins. Neither schematic that David just sent can be it...the one has 7-pin miniature tubes....the other has SIX octals...yours only has 5.   Icon_wtf
Hold the presses!
The "miniature" schematic also has octals listed below the miniature numbers.....never seen that before....so it might be your schmatic.
Jake take a look at the Hallicrafters series S-38D an S-38E  8pin vs 7pin tubes . the cabinets are different but the only real difference under the hood are the tubes. Marketing at its finest!! Have a Happy New Year.
"Jake take a look. . . "
Yes sir!   Icon_idea
Is your power supply adequate? Perhaps it cannot source the current required. Or...bad transistors.morzh — 09:32 AM
Hi R3, just glancing over the schematic,if C1 and C2 are good and they appear to be by the voltage you are getting on TP...462ron — 08:28 AM
42-345 Resistors
Those wax-paper caps, if they have not already failed, are very likely to fail, and the same is true of the old electrol...DaleHCook — 06:48 AM
What make and model of power supply are you using? Is it regulated? Have you tried measuring the current drawn by the ra...DaleHCook — 06:43 AM
Ooh, backlighting will be a nice addition! I’ve got a 70’s model GE clock (not the kind with the numerals on cards that ...jrblasde — 12:26 AM
Hello Joseph, You have been really busy on this set it really puts me to shame !! Great job so far I finished up my 1...radiorich — 12:08 AM
One radio, check. I connected the power wire to 12.2v. I measured all of the voltage on the wires on the potentiometer...R3Sons — 11:53 PM
Good evening, folks! I guess I’ll provide an update on this week’s progress. I am awaiting one last order from Mouser, w...jrblasde — 11:41 PM
OK, experience with electronics helps. What do you mean by " draw 5-7 volts"? Amps are drawn, Volts are ap...morzh — 09:43 PM
Sorry, point 19 was 10vR3Sons — 09:11 PM
There are currently 1946 online users. [Complete List]
» 4 Member(s) | 1942 Guest(s)
AvatarAvatarAvatarAvatar
