Knobs for my 112.
I need all four knobs for this radio. It uses the "rosette" style. Antique Electronics Supply seems to have used to have reproductions of them, but are now sadly all out of stock.
Does anyone know of another source for these?
Yes, Audin...send a PM to Phorum member ekimetsok. Mike Koste "Gobs of Knobs" sells original knobs, and his prices are very reasonable.
There are currently 9468 online users. [Complete List]
» 2 Member(s) | 9466 Guest(s)
