37-116: Pick Up or Ship?
It did finally arrive in good shape. It showed up a couple days before Thanksgiving. It was sturdily boxed in cardboard lined all around with what I think was an inch of Styrofoam.
I was a little surprised that the chassis was shipped inside of the cabinet. But the chassis was locked tightly in place with wood blocks into which the studs on the sides of the chassis were inserted. I suspect that's how they were shipped from the factory as I've seen photos with the blocks still in the cabinet, but apparently not engaged with the chassis.
I'm certain the chassis isn't supposed to be held in place like that in use. Please correct me if I'm wrong, but I think there's only supposed to be one screw in the center of the back of the chassis holding it in place. I don't think it's even bolted to the cabinet through the 4 corner chassis "cushions" (rubber grommets).
I just started working on the chassis the other day. I'd post some photos as I go but I would only embarrass myself by showing off my glacial pace Icon_biggrin.
I usually clean/fix the parts as I remove them since I hate to have to clean them when I put it back together. And there are a lot of parts in the automatic tuning mechanism. I had forgotten how many. I'll remove, disassemble and clean it up then move on to the stuff I'd rather do.
Greg O.
Whitehall, PA
Have fun!!  I did with mine, and am just about ready to start another.  Band 2 oscillator coil was bad on mine as it has been on most of the others who have tackled these radios.  I would definitely suggest removing that coil and rewinding it.  I will on the one I'll be doing soon.  Nathan has a thread on one of these as do I. You have to go back a few pages in Electronic Restoration to find them.
Restoring Philco 96
Spraying Deoxit inside did the job; today it was dry and still showing 0.25 Ohm when the switch is made. So, I put it...morzh — 07:49 PM
1950 Emerson TV resurrection attempt
Thanks Rich! This is kinda typical in TV work and is one reason I don't shotgun things. If something like this goes wron...TV MAN — 05:17 PM
Hello Tim, Yes, don't you hate when things go like that and go snap ? Anyway lots of progress on your tv . Sincerel...radiorich — 03:32 AM
I needed to loosen the HV tube socket, so that meant removing the 1B3. The getter looked ok, so I'll reuse the tube. I c...TV MAN — 01:40 AM
Today I got some final (I hope) work done. I know there are some that absolutley blast me because ... "WHY don't yo...TV MAN — 01:11 AM
42-345 Resistors
Hello Tom, I hate that when that happens We have all been there and here is a short video and page  about safety capaci...radiorich — 01:01 AM
42-345 Resistors
Mike, Thank you for the reply and for correcting the year on my subject. Little and Big Phil are indeed 42s. The b...proftrussell — 12:13 AM
32-345 Resistors
You seem to have gotten the values right. Yes the damage is consistent with a wrong polarity of the first rectifier filt...morzh — 11:47 PM
42-345 Resistors
Phorum Phriends, I have some questions about resistors in my 42-345.  Before getting to the confessional aspect of...proftrussell — 11:28 PM
Canadian GE Model 41
Umm....you do not clean potentiometers with contact cleaner. Unless cleaning the carbon layer of the base is the goal. Y...morzh — 05:52 PM
There are currently 1227 online users. [Complete List]
» 1 Member(s) | 1226 Guest(s)
