Today's find. 40-205
Found this today for.  After a quick dusting and a little Olde English, she doesn't look half bad.  IT plays too.  I know, I know.....I will get it restored. But when I went to pick it up, they had it playing. It sounded great, with lots of volume, and good tone. Picked up a ton of stations, unlike some of my other radios.
Its a 40-205xx.  Not sure of the proper suffix letters.  I think this might be the one that took the wireless remote. Not sure.
I'm kind of on a roll this week.
[Image: https://i.imgur.com/zj4LTWE.jpg]
[Image: https://i.imgur.com/faKv0nB.jpg?1]
[Image: https://i.imgur.com/6mJPp4x.jpg]
[Image: https://i.imgur.com/zGJkILB.jpg]
You've have the radio bug, take 2 tubes and call the radio doctor in the morning. Paul
Oooh,
That is pretty! It even has the indicator jewel still...
Vey nice
Kirk
Nice looking...
Anybody here own one? The volume is locked on this one. I think it has something to do with the Mystery Control setup. There is a little prong that sticks out and doesn't let the volume dial move more than a 1/4 inch or so. I can see that if it wasn't sticking out, the dial would spin freely. I can't get it to move out of the way.
[Image: https://i.imgur.com/ddMEvDD.jpg?1]
Ok follks.....REVELATION TIME!!!!!!
The volume wheel is just an up and down SWITCH!!!!  I was expecting it to be a rheostat with a lot of movement, but it just goes UP a little bit and DOWN a little bit, to make contact with what is seen in my photo. That prong sticking out is what moves it up and down a little bit to make contact.  I needed to WAIT for the motor to turn the volume up or down.  AND I wondered how you turn it off because there's no on off switch.  Guess what?  I hold DOWN on the wheel until the volume goes all the way off, and them wait a few seconds, and the power is turned off.  SO there is nothing wrong with the volume switch, it was just OPERATOR ERROR.
Nice radio. It looks in really good shape. Nice find! Thanks for sharing.
The power volume control uses a 2 ph motor. By exchanging the motor condenser connections the rotation changes, that is what the up/down volume control does.
Outside of other possible mechanical issues, the condenser for the motor usually dries up so no rotation or very little torque...
It is a non-polarized but I have used two regular electrolytics back to back, doubles the voltage rating and halves the mf rating...
If there is a large, open wire loop at the bottom of the cabinet, that is the receive antenna for the wireless remote...
YMMV
Chas
Pliny the younger
Yes, I tested them out of the circuits. I posted my measurements where the first letter was red and the second was blac...R3Sons — 08:52 PM
1. Have you tested out of circuit? 2. If yes, any transistor not showing E-C as OL is bad. From your measurements, all...morzh — 08:27 PM
42-345 Resistors
In short (I a sure you've seen the video Rich provided), safety caps are X and Y. X caps are placed across the Line/Neu...morzh — 08:21 PM
Restoring Philco 96
Today I decided to take on gutting the big bad cap block. I gave up on the same one from the 86 before, so I was not sur...morzh — 08:13 PM
42-345 Resistors
To not replace is to put it on the list to do later when they cook up! As a radio guy would say back in the day, lets sp...Paul Philco322 — 07:19 PM
Here's the readings from the AR14 (No markings on the one from the 5TPO) on the 6TPZ: B-E OL E-B .14 B-C 2.9 C-B .13...R3Sons — 04:17 PM
Thank you all so much. First the power supply: "KORAD KA3005P - Programmable Precision Variable Adjustable 30V, 5A...R3Sons — 03:48 PM
Perhaps I am missing something - which volume (AR-28 or AR-33) has the 6TPZ?DaleHCook — 12:16 PM
1950 Emerson TV resurrection attempt
:lol: Ya got that right Mike! I watched it some last night for a couple hours and it seemed pretty stable. Not bad for a...TV MAN — 11:05 AM
Is your power supply adequate? Perhaps it cannot source the current required. Or...bad transistors.morzh — 09:32 AM
There are currently 3252 online users. [Complete List]
» 5 Member(s) | 3247 Guest(s)
AvatarAvatarAvatarAvatar
