Need an ID on this floor model
Hi all, a friend of mine is getting this floor model and wants to know anything about it. I have the feeling it will end up on my bench so, any idea on what brand it is and model/chassis?  Thanks
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Nothing under Philco, GE, Silvertone, Admiral, Crosley, or Airline so far...
Icon_smile
Can't see the dial face clearly but it might be a Truetone.
Ok, my friend got the radio in her possession and it is a Silvertone chassis 101.616. It came with a complete parts list, schematic and alignment instructions! It's a 12 tube unit with a tuning eye! And the best part, it was FREE ! Icon_clap
Ron
Ok, since it isn't a Philco, maybe a moderator could put this in the "other radios( non-Philco )" category! Thanks.
Ron
Philco 91 Tuning Condenser
There are currently 7994 online users. [Complete List]
» 2 Member(s) | 7992 Guest(s)
