46-1226 grille cloth removeal
can anyone tell me how to remove grille cloth that's in good condition with out damaging it... I'm getting ready to refinish cab and i am worried about getting finish on it ,,it looks like it is riveted on
thank,,,john
never mind i found out their tacks
Glad you found the answer. It's been so long since I messed with a 1946 Philco radio/phonograph that I had forgotten how the grille cloth and backing board were held in place.
There are currently 9719 online users. [Complete List]
» 1 Member(s) | 9718 Guest(s)
