46-1201 No antenna (Sorry, I had 1601 in the title originally)
Threads: 3
City: Davis
State, Province, Country: CA
This should be simple, I just want some guidance.
I picked up a 46-1601 (EDIT: NOPE, A 1201) for free last weekend. I did a recap of all the electrolytics today, and the buzz is now gone.
Unfortunately, the antenna is MIA. The two thin wires from the chassis are hanging out there, but there is no trace of the actual antenna.
What shall I do? If this was your radio, what solution would you suggest? I'm thinking I can just make a loop with thin wire and call it a day, but maybe there is a more elegant solution?
Mark
(This post was last modified: 02-15-2020, 06:06 PM by Mutantmoose.)
Threads: 114
City: Sneedville, TN
First, I am not familiar with that radio, but here are some ideas. All of them involve your making a back for your radio. You can do this by cutting one from thick pasteboard, or cut one from masonite you get from a home supply store. You actually have several options. You could just buy a modern ferrite loopstick, connect it to the existing leads, and mount it to the new back using some plastic wire ties. If it is the tuneable kind you can adjust it so it gets the best reception. You could also cut a form from cardboard, slightly smaller than the radio back, and cut slots around the edges, an odd number, and wind wire around it, weaving it in and out of the slots,, about 60 to 70 turns (you can always remove turns if there are too many) in a similar manner to what is outlined here:
[Image: https://66.media.tumblr.com/74b276abc1d3...a80431.jpg]
again, mounting it inside the new back. Hope this helps.
Threads: 44
City: Roseville, MN
Hello, there's a long thread on this forum discussing alternative antennae. Just do a search for antenna. My two cents is near the end showing a good example using a 6 foot ethernet cable. Alternately connect the wires so you end up with a 48 foot antenna, then coil it inside the cabinet. BTW when I did a search for the 46-1601 I got nothing.
Rod
Threads: 268
Methinks it's a 49-1601.
Threads: 3
City: Davis
No, it's a 46-1201. My mistake. I shouldn't type when I need sleep. It's the good 'ol Bing Crosby model.
Threads: 3
City: Davis
I found the thread - excellent advice! Thanks so much, and again, my apologies for the model confusion.
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
There are currently 4278 online users. [Complete List] » 4 Member(s) | 4274 Guest(s)
