Stromberg Carlson AWP-8 transoceanic radio
Newest member of the family. Real clean, and sounds great.  The temp gauge and barometer still work, too.
[Image: https://i.imgur.com/mbMoWGj.jpg?1]
[Image: https://i.imgur.com/Ib6EbJE.jpg?1]
That is in modern parlance the "Bomb". Paul
Great condition.
I have one also but in Blue/Green Color, my Barometer and Rain Gauge work too.  But your map on the bottom door is in better shape than mine is.  My case is in Great Shape too,  Enjoy it!!
Eico 232 VTVM Schematic
There are currently 6705 online users. [Complete List]
» 1 Member(s) | 6704 Guest(s)
