02-24-2020, 12:26 PM
Hi. I have a philco 42-1008 and the RF choke is disconnected on one end. Part 26 on schematic. One end goes to the C75 tube but can anyone tell me where else it connects too. I don't want to guess. Thanks guys
Philco 42-1008
02-24-2020, 12:55 PM
02-24-2020, 01:25 PM
Thanks . I do have the schematic. Having trouble deciphering it. Just wondered where I solder the second connection to
Thanks again
02-24-2020, 02:22 PM
Say your new here! well welcome!
It goes to the junction of #27 (.01, #29 15,000 resistor,and 220,000 ohm resistor #28). Gud luck with your project! When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got! Terry
02-24-2020, 02:36 PM
Thanks for the welcome guys! I will study it when I get home. I also have a bad ground somewhere. Crackles and pops touching the chassis or anything else. Is that a matter of just checking the solder on every ground on the schematic?
02-24-2020, 08:29 PM
Hard to say on the '42 models you've got two strikes against you. One is that it's wiring insulation is probably failing and the other is poor connections @ the loctal tubes. All this is assuming that the chassis that been serviced w/replacement parts.
02-24-2020, 09:32 PM
I've changed all the caps and out of spec resistors and replaced any crumbling wiring. Tube pins and band switch cleaned. I have no reception unless I touch the top of the first I.F. Can. Then I can pick up stations by messing with the 2nd I.f. can. The oscillator fails the second radio test. Hoping a new rf choke gets the oscillator working. I'll keep looking for the bad ground
02-24-2020, 10:26 PM
#26 provides the plate voltage for the osc so if it is open or disconnected the osc won't run. If you have been dittiling with the trimmers associated the the IF transformers you should use a signal generator and align them properly to the IF frequency. If not your asking for poor performance.
02-24-2020, 10:46 PM
I have a signal generator and plan to align it once I get the oscillator working and can hear stations on the tuning condenser. Thanks for your help so far. I'll update when the new choke arrives.
05-14-2020, 11:45 AM
Hi
Does anyone have the specs on the rf choke for this model? It's part 32-3615. Number 26 on the schematic.I need to order a new one but I'm not sure of the mh, ma or ohms. I'm only getting 15 volts to the 7c5 and xxl tubes and I think a bad choke is the reason. Is it needed or can I jump across it? Thanks again Jim
05-14-2020, 01:12 PM
Check 29 and 42 before taking the leap of replacing the rf choke.
https://philcoradio.com/library/download...20Book.pdf They use to tell me that I would blind if kept doing something?? I figured out what it was. Reading schematics from NA!!!!!!!!!!!!!!!!! When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got! Terry
05-14-2020, 03:32 PM
29 measures 14,700 and #42 measures 24,000
05-14-2020, 04:45 PM
The choke is going to be abt 2-2.5mH@ 20ma.
05-14-2020, 04:56 PM
Thanks Terry, I will see what I can find
« Next Oldest | Next Newest »
Users browsing this thread: 5 Guest(s) |
