Philco 38-35 Antenna Length?
I am using number 18 wire. Would 25 feet be enough for reception?
Thank you,
Oscar
Hi, I looked at the schematic for a 37-93, which has a very similar circuit, and it shows a consumption of 50 watts, less than half an amp of current.
Rod
Oscar,
Should be enough. How far are you from the AM stations?
There are currently 3917 online users. [Complete List]
» 2 Member(s) | 3915 Guest(s)
