40-150 recapped, no reception
Threads: 5
City: Boston
State, Province, Country: MA
Hi all.
I just finished recapping a model 40-150. Re-covered or replaced all the old cracked rubber wires, all caps replaced, tested all resistors and replaced all that were out to any degree. Powered on. No fire : + )
But... no reception. volume is working, but no stations coming in on AM, police, or shortwave.
Can you help me with the next step to troubleshoot this? Schematic attached.
Thanks for any help/advice you can provide.
Threads: 72
City: Linn Creek, MO
First thing you will want to check the oscillator. Use a second radio tuned 455 KC above the 40-150. So, tune the 40-150 to say 1000 KC, tune the other radio to 1455 KC, rock the dial on either radio, if the oscillator is working, you will hear rushing/whistling sound.
M R Radios C M Tubes
Threads: 242
City: West Bend, Wisconsin
I'm going to throw this out there because it happened to me on my 40-180 and it's an easy thing to overlook. You need to have the dial button (last button on the right) pushed in or the set won't receive by conventional tuning. At least not on the standard broadcast band.
Threads: 69
City: Kansas city, MO.
To add to the above ideas, make sure you have some type of antenna connected.
Threads: 4
City: Monteith, Ontario CA
Did it work before you started replacing parts?
Do you have any test equipment? Signal generator, scope ?
Threads: 5
City: Boston
YES!! The push button was the issue! Also, I found that hooking up all the wires on the antenna improved reception. I thought that the three related to the phono jack would have no impact on reception, but it definitely improved when I connected them as well.
Standard broadcast reception is good. Nothing on Police Band, one station so far on shortwave, but will check that again tonight, when it tends to be better.
THANK YOU ALL for your help!
Threads: 5
City: Boston
Ready to go back into the cabinet. Thanks again.
Threads: 69
Looking good. I have one and it's a good sounding radio.
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
There are currently 4300 online users. [Complete List] » 4 Member(s) | 4296 Guest(s)
