Philco Vol Ctr
I took this volume control out of a Stewart Warner radio it was the wrong control for that radio.
Philco 45-5027, 500M-A, 304723.. Has four terminals on the volume control and has ON/OFF switch.
Could not find info on this, what model Philco would this have come from.
Thank you, please stay safe.
Jim
Spring Lake MI
It may or may not have a direct Philco application as 500k is a very common value and it may have been made for a general replacement part. The fourth terminal is for part of a tone compensation circuit which boosts bass @ low volume levels.
Thank you
Jim
Spring Lake MI
There are currently 3892 online users. [Complete List]
» 1 Member(s) | 3891 Guest(s)
