Model 70 field coil resistance
Hi
Does anyone know what the field coil resistance is for a model 70/570 chassis with 1, 47 tube ?  My field coil opened, and am trying to find a replacement speaker
Thx
Bruce
Hello, 3100 ohms
Here is a link for some information.
https://philcoradio.com/library/index.ph...-21-70-90/
Thx
That gives me what I need ?
It is 3100 ohms. This is what you asked, this is what Mike said.
The replacement is any K-type speaker, they all have the same Field coil and voice coil.
You need any Single ended transformer type, from 70 or 90.
The 20 will also work. But I don't think it should be used, though with the transformer changed it is the same speaker.
I just did exactly that, my 570 had a 20 speaker with bad xfmr, and I had a spare xfmr from a 70.
There are currently 4519 online users. [Complete List]
» 1 Member(s) | 4518 Guest(s)
