Philco chassis idenification. 65?, 87? ???
Threads: 2
City: kingston
State, Province, Country: Michigan
From what i gathered I got a Philco 65 low boy [Late] cabinet, but the chassis diagram dont match up according to the wiring diagram.
I bought the missing tubes based on what a 65 needed.. i have 2 unoccupied tube sockets. the tubes in the pics are a 224, 227, 227.
the 224 has the top hook up, and the 227's are either side of the transformer. that's what it came with. according to radiomuseum an 87 doesn't use 224 tubes. ( 26 26 26 27 26 45 45 80)
I may have a swapped chassis and be on the wrong track for the tubes.
I'm use to working on modern technology. i'm having a hard time finding the information i need and getting it working.
The only story i have on it is it belongs to my stepdads dad or grampa. i'm trying to get it working as a fathers day gift.
Threads: 268
Hi and welcome,
It's a 95 or 96 both are abt the same.
Threads: 49
City: Allendale, MI
Threads: 268
It's a model 95.
Notice the cylindrical capacitors, and the large format speaker socket - 1929 design. Philco switched to the bakelite block capacitors in mid-1930 when model 96 was introduced; the 96 also used a much smaller speaker socket.
Threads: 2
City: kingston
Thanks a lot guys, much appreciated. Sorry the middle picture was a little blurry.
I was starting to think it was a 96 after looking at more schematic photos. but then i seen a 96 chassis picture and it looked a little different.
I also forgot to make sure i was subscribed to my thread.. On most forum sites that's automatic. oops..
i got all the tubes for it. just need to replace the rest of the caps i wasn't sure about. The schematic link Radiorosyln posted helps a ton. thanks!
it helped me understand part 3787-A a lot better too. I didn't want to do anything with those until i was absolutely clear on it.
a reddit post i found talks about replacing carbon resistors. is that necessary? and all im seeing is wire wound resistors unless they look way different that what im thinking.
In the philco library im seeing a 95 early and 95 later schematic. https://philcoradio.com/library/index.ph...chematics/
I downloaded both im not sure which i have. but there is little difference and I'll probably find out which when i have the time to do a thorough investigation of the wiring.
Threads: 268
I just check to see if they are within tolerance (20%).
Threads: 2
City: kingston
okay, thanks for the help. I'll get into it this weekend.
i subscribed to receive an email notification of new replies but didn't receive any...
Threads: 34
City: Elkhart
check your spam box, the email notifications from this site always end up in the spam box (that's the way it is with me anyways and I even tried adding the notifications email address to my safe sender list and it still ends up in the spam box, because apparently they use several different notification email addresses, from what I could see because no two notification email addresses are the same).
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
There are currently 4394 online users. [Complete List] » 2 Member(s) | 4392 Guest(s)
