Threads: 49
City: Allendale, MI
That's the one. I paid more like $5 each as I recall. Got a bunch of them. PM me your address. Yes it is easy to change the fuses. There is a fuse in each leg of the plug. they slip in from the plug end. There is a small hole on the cord end that allows you to push the fuses out.
I've been using them on several radios to avoid putting a fuse holder under the chassis. The biggest problem with them is that they stick out from the wall a bit more than a normal plug.
Threads: 569
Thanks!
PM is on its way.
So I guess I will chop off the end of that triple outlet that is on the radios' wall, and put that Elmenco instead, it shall then protect everything from the plug up.
I still need to plug something it the triple outlet, again, won't acept a polarized plug.....but this can be taken care of.
Threads: 55
City: Lexington, KY
Those plugs are pretty slick. The first time I ran into one was on a tube tester when I replaced the cord about a year ago for a friend. I doubt it was OEM on that tester but I was impressed when I realized it held two fuses and how easy they were to change.
I might have to pick one up so I can leave my 570 plugged in all the time.....
Threads: 569
John
What would you think a fair offer for 10 of these would be?
The guy also wants $15 for postage, so this is part of the cost?
Threads: 55
City: Lexington, KY
Maybe $50? With shipping that's $6.50 each, but I've never priced them before. I'm sure there's a dusty box of them somewhere for $5 or $10 but we don't know where they're at
Threads: 569
Rfeenstra,
Let's wait 'till tomorrow, I made an offer to the guy. If he does not accept, then I'll gladly take you upon your offer.
If he does then I will have some.
Threads: 569
So...I made an offer....he countered....I countered...he accepted, so I have the whole thing for the same as he listed it without shipping.
It comes to $7.43 apiece, and it ain't bad considering when sold piece by piece, the asking price iz $11-$14. Too much if you ask me.
So.....if nothing bad happens to the p,ugs while in shipment (lost-stole-crushed) I can have my 570 start keeping time and I will be able to see how well it does that.
Rfeenstra,
Thanks again for the generous offer.
Now waiting for the grass.....plugs to come.
Threads: 55
City: Lexington, KY
Glad you got the plugs Mike.
Threads: 569
OK,
The plugs came both from eBay (Elmenco) and Amazon (non-polarized, cheap, like $1.50 ea). The Elmenco goes to the outlet plug and the brown one goes to the 70 chassis plug to mate with the doubled outlet inside the cabinet.
Just realized need larger fuses size. I have 5x20 and need 6x30 mm type.
Have to order.
Ok, it waited 4 years...will wait a week more.
Threads: 569
Forgot to mention:
I put the fuses in and plugged the clock into the outlet on May 23rd.
I am pretty amazed that in these 3 weeks the 570 clock shows no difference in the time it shows with my Seico wristwatch I used to set the time.
Very impressive.
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
There are currently 3108 online users. [Complete List] » 1 Member(s) | 3107 Guest(s)
