Model 70 plate to ground question.
Threads: 13
City: Clemmons
State, Province, Country: NC
Still working on this unit. I measure 7k ohms first detector (converter 2nd 24 tube) plate to ground - all tubes installed playable unit, the volume control does nothing to alter it. Is the first IF coil leaking or normal?
https://www.philcoradio.com/images/phorum/schem/70a.jpg
Threads: 569
No it is right. Your wirewound #37 divider plus the #36 field coil and the F to G volume regulator do this.
Simple test, remove the speaker, then the curcuit should become open.
Threads: 13
City: Clemmons
Shouldn't the volume control vary the ohms? The volume intercepts the wireround, my field coil is just resistors.
Threads: 13
City: Clemmons
I removed the speaker, still obtained 7k ohms.
Threads: 72
City: Linn Creek, MO
7K sounds like a good number. You have the winding of the IF transformer, a field coil, the volume control and three resistors in the BC resistor all in series to ground, should come out pretty close to 7K.
M R Radios C M Tubes
Threads: 569
You mean you UNPLUGGED the speaker altogether and still got 7K?
Oh...wait, you have permanently replace Field coil with the equal value resistor?
Then yes, unplugging the speaker will not affect anything and this will remain about 7K.
And no, the volume will not vary anything. Not just because it is low value compared to the rest of the divider, but the wiper is not part of the circuit.
Threads: 13
City: Clemmons
Thanks for info, whew for me, the volume control confused me, but I guess it's a path to nowhere until fired up. Thinking about it, what a wonderful upfront test to check for failure areas.
(This post was last modified: 06-25-2020, 08:01 PM by radio1.)
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
There are currently 4518 online users. [Complete List] » 2 Member(s) | 4516 Guest(s)
