radio manual philips he 554-a
Hello friends:
A few years ago I bought a philips radio model he 554-a I am looking for the manual and schematic today I have plugged it in after several years the record player works but it does not pick up the channel it makes the typical noise of searching but I ask you nothing please advise me and tell me What can happen anyway when I was trying to find a channel there was a loud noise or humming, I don't know where it comes from, please, if you can give me some advice, if I can, I'll put a picture in the afternoon.
A greeting.
Found this info.   https://www.radiomuseum.org/r/philips_he554ahe_554.html
There are currently 6151 online users. [Complete List]
» 2 Member(s) | 6149 Guest(s)
