Looking for Photo - Crosley 425 Table Radio
Looking for a picture of the Crosley 425 Travo, Needs to be color.
Thanks
Russ
If you need more photos, Russ, let me know.
I have a Constitution with original finish, I should be able to get you detail photos.
The 915 is all done. Going to buff it out tomorrow.
Thanks for the offer.
But - now I could use a photo of a Crosley 425 (Travo), in particular the color of paint used in the groves - silver?
There are currently 2046 online users. [Complete List]
» 2 Member(s) | 2044 Guest(s)
