Philco 46-1203 record player cover
Have a problem with the cover for the record player not opening all the way..
[Image: https://live.staticflickr.com/65535/5021...1ce7_c.jpg]
[Image: https://live.staticflickr.com/65535/5021...67cc_c.jpg]
Will not open past 3/4 way  do not want to force it  What am I doing wrong?
Skip
If you remove the two screws on the side bracket, open the lid all the way, and re-attach the side bracket with the pivot arms up instead of down, it should work.
Roger That It worked
Thanks
Skip
Eico 232 VTVM Schematic
There are currently 6596 online users. [Complete List]
» 3 Member(s) | 6593 Guest(s)
