40-155 dial cord restringing guide???
Threads: 14
City: Bakersfield, CA
I recently picked up a 40-155 with a broken dial cord. Does anyone know where I can find a guide for how to restring this model, or one of its equivelants (like the 40-150) that has the dial cord set up.
I have the path that is on the Rider page for these models, but its a little more vague than I would like.
I'd like something that shows me the proper path and length. Is that asking too much. I found nothing to really help me as I searched the internet this afternoon!
I can guess at things, but perfer not to do so.
Thanks for your help!
Threads: 242
City: West Bend, Wisconsin
You probably already found this PDF, but here is the actual Philco service information for your set. There is a basic restringing guide illustrated:
Unfortunately, as many of us have found, restringing a missing or broken dial is often trial and error. Mostly error. You're lucky to have found ANY re-stringing diagram, however vague it may be. Certain radio brands do have better guides than others but many (read most) have none at all. I have found some with the length of the cord laid out straight posted, but not often. I did the dial a few years back on my 40-180, but I neglected to document the path and length. Patience is a virtue, so if it gets frustrating, take a break and try it again some other time. Each time you try it (make sure you have a lot of extra cord on hand) you will get a little closer to the needed outcome. Good luck!
Threads: 14
Thanks, Greg. The diagram is similar to the one in Riders. I guess I'm resigned to trial and error.... and buying extra cord. One more opportunity for character building and growth, right? Thanks again.
Threads: 44
City: Roseville, MN
I found this one in Beitmans, see if it works.
Threads: 242
Rod: That's the exact same one as what is shown on the Philco service info, so that must be the "go to" diagram.
Threads: 14
Thanks Guys! I learning how to the perfection loop knot and have the original cord. So, I have an idea of it's actual length.
I'm in the process of ordering some new cord from Bob's in LeGrange Park.
One other question - it looks like I have to take off the dial glass mounting bracket so I can get to the cord wheel that's hidden. Sound right?
Threads: 242
I don't recall doing that on my 40-180 (the console version of your set), but if it makes it easier to get to I don't see why not. Other than you'll need the dial glass on to align the dial pointer properly.
Threads: 20
City: Greenville, TX
Start with an extra foot or so of dial cord, follow the diagram and cut off the remainder at the spring.
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
There are currently 4544 online users. [Complete List] » 2 Member(s) | 4542 Guest(s)
