Threads: 569
Aligned the set.
The procedure is well-hidden, but I unearthed sometging from the 89 Rider article.
Very simple alignment. Just IF (3 padders) and 1500 kHz. The lower frequency just aligned itself.
Now have to put it back together and clean up the exterior a bit.
Threads: 49
City: Allendale, MI
You're standing on your head to take that pic!
Threads: 569
No. This is the way it is, the chassis is for the LZ so it is oriented this way so when itis horizontal, the wheel is upside down.
Threads: 55
City: Lexington, KY
So far so good Mike
Looking forward to a picture when it's back in the cabinet...
Threads: 49
City: Allendale, MI
"This is the way it is, the chassis is for the LZ so it is oriented this way so when itis horizontal, the wheel is upside down."
That's right, it's a chair side. Duh!
Threads: 569
I took the picture of what I saw while giving the chassis one last look:
Remember when I said this chassis is ...tight?
Yes. This tight. The first cap of the tone control is practically touching the grounded electrolytics mounting bracket. And the voltage there is the plate voltage. Safe, as all it would result in is the first cap getting engaged. But....so I had to bend it out. It is possible the bracket got moved a bit when put back in place. Still too close.
Anyhow, I put back the rear cover to the speaker cabinet and gave it a GoJo bath.
I also sprayed the asbestos-lined metal screen with hi-temp finish, same I did for the Transoceanic.
Tomorrow hopefully I could reassemble the chassis into its cabinet, give the cabinet a GoJo bath, and it should be over then.
I have to say, it sounds really good. Not 38-690 good, but really, really good.
Threads: 569
Well. I gave the radio cabinet GoJo wipe.
I made some pictures, but this is with the tablet and not a very good lighting.
This said, of course, the radio cabinet could use refinishing, though the speaker cabinet is fine the way it is. Not ideal but it looks decent to be preserved.
The sound is good. I like it. I took it out from my workshop to put with the general population. Too bad the space in my basement starts shrinking, and I do not think my wife wants it upstairs.
It will have to live in the basement for now.
It is no longer upside down.
This concludes it for now.
Threads: 55
City: Lexington, KY
Looks good Mike
They're survivors and a few blemishes here and there after all they've been through can be overlooked.
Threads: 242
City: West Bend, Wisconsin
Excellent work, Mike! There's too much good finish left to merit refinishing. Leave those "battle scars of a bygone era" intact...it gives it some extra character!
Threads: 569
My thought exactly.
I wish I had some sort of account somewhere that allows videos. Unfortunately U-toob is no longer an option.
This is one good sounding radio.
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
There are currently 4198 online users. [Complete List] » 2 Member(s) | 4196 Guest(s)
