Model 70 Trim
I bought a Model 70 with a walnut cabinet. I am thinking about replacing the bottom trim. Is it made out of walnut?
Thanks, Ray
I honestly do not know if the trim was specifically made from walnut. I suspect it was not, probably made from cheaper wood and then toned medium walnut color with tinted lacquer, along with the rest of the cabinet.
Send Phorum member Steve Davis a PM, he can fix you up with some new molding. Or go here:
http://www.philcoradio.com/davis.htm
Thanks
There are currently 8823 online users. [Complete List]
» 3 Member(s) | 8820 Guest(s)
