Threads: 34
City: Elkhart
Alright so I've started tearing into my Philco 42-350 I just recently acquired and both dial strings are broken and missing along with the springs for them, and also the preset buttons are not working right and also the power switch isn't engaging and disengaging like it should, and I was wondering how I would go about repairing those items, specifically the power switch push button and the preset buttons.
Threads: 569
Deoxit D5.
https://www.walmart.com/ip/CAIG-DeOxit-C...8=&veh=sem
Do not buy swivel head. Buy regular spray can.
Threads: 20
City: Greenville, TX
The power switch is not repairable. Suggest you replace the volume control with one that contains a switch on the rear.
Threads: 569
Could you put here a good photo of the switch?
Threads: 34
City: Elkhart
OK, so here's the dealio, the power switch is working its just very sticky (it engages like it should, but it disengages with a little force, which I think its because the pushbutton mechanism needs a good lubing with WD40 or something like that.
However the preset buttons though I think are a lost cause because the little phenolic wafer in there that sets the travel/locks in the preset buttons is broken (see picture below), and unless there's a way to repair that I think the preset buttons are just going to have to remain unusable unfortunately.
Threads: 569
Try Deoxit D5 first, it seems like this type of switches is not sealed very well so it will penetrate - use the spaces around actuators. Unless the contacts are on the surface in the open - I am not sure what I am seeing tehre. If in the open - desolder, soak in mineral spirits, brush.....lots of grime there. Acetone might work too, if it is not plastic but a fenolic board. Of course do it outside, don't inhale.
Then once it dries, use Deoxit F5 - the fadder lube, it will take care of friction.
Other switches....try the same first. If it does not help - then, ok, look for a donor chassis.
Threads: 34
City: Elkhart
The area in the red circle is the broken phenolic board joint.
That's the phenolic board piece that helps control the preset push buttons, unfortunately because it's broken it don't allow the preset push buttons to function anymore, the power switch isn't affected by that phenolic board.
Threads: 569
Yeah....that will take a replacing to do. Phenolic boards, especially those constantly moved, do not glue well at all. And that is, if there is something left to glue to.
Threads: 49
City: Allendale, MI
Try epoxy or super glue????? Mike is most likely correct, though. On my 41-295 I was able to replace/repair the push button switch. I found a new switch that I was able to use parts of to repair the original. Drilled out the rivets and replaced them with machine screws. I don't have any pics. It is working perfectly.
(This post was last modified: 10-03-2020, 02:34 PM by rfeenstra.)
Threads: 569
I think he has pieces broken off that are no longer there, so there is nothing to glue with.
If he finds other parts to cannibalize - then yes, but then no gluing would be be necessary.
I was able to repair my Zenith tone ctl switch but then that is not moved often, and I since glued it once again. Think phenolic wafer.....many people break it when pulling Zeniths' chassis out of cabinets.....I had to gain my own experience
Threads: 34
City: Elkhart
All the parts are there for the phenolic board it's just whether or not they can be glued back together and stay glued.
There's a spring and metal clip holding part of the phenolic board into place that I can't seem to get to come loose, that's what's holding up the works right now, and that spring is what causes the push buttons to spring back out when you push another button in.
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
There are currently 4194 online users. [Complete List] » 1 Member(s) | 4193 Guest(s)
