Philco 41-300 Tone Control Knob Removal
    How do I remove the brown knob? Cannot rotate it any further CCW.
I got one apart a couple of yrs ago but done remember how. Can you loosen the nut on the pot and manipulate the shaft/gear on an angle to slip thru the hole? They put it together so it's got to come apart. Don't think they welded the gear on after the knob was fitted.
Eico 232 VTVM Schematic
