Philco 71tone control internal cap value
Hello all, I hope you are weathering the pandemic storm and are doing well. I am starting my first fall project a model 71 cathedral. The tone control, item# 39 in Beitman's parts list lists part number 04757 but gives no value. The part number on my tone control is 05153. The radio looks untouched and this appears original, but no idea. My wires are of course crusty and will need to be gutted and replaced. Any help is appreciated, thanks.
There are 2ea. .01 uf. inside.
Look here under 1932, the schematic for the 71 is there with the value of parts.
https://philcoradio.com/library/index.ph...chematics/
https://philcoradio.com/library/index.ph...chematics/    Always best to look here first, Ron has got to a lot of work to mark the values on these schematics.
M R Radios   C M Tubes
Ok thanks Dale. I cannot find a clear schematic the item designators are blurry and I only see one cap in the schematic near the output tube; do you have a better diagram? Sincerely, Jeff
Got it, thanks all, have a great day!!
Jeff,
This will help.
Dale that sure does help, thank you very much!!
There are currently 4430 online users. [Complete List]
» 1 Member(s) | 4429 Guest(s)
