38-2 cabinet
Hi Folks, I'm in the middle of restoring a 38-2 cabinet. The sides are really in bad shape. Underneath the veneer is a 1/16 layer of some kind of wood. Does anyone know a good source for this? Or maybe what the official siding is called so I can ask the right questions? The smallest I can find is 1/8 in a ply, and a bunch of different veneer at 1/16 or smaller.
