A Philco Boo-Boo??
Maybe I'm missing something but I appear to have a Philco 38-10 chassis in a 38-9 cabinet which is actually labeled a 38-10.
I've had plenty of coffee today so I am awake!
Craig R.
I suspect Philco was just being thrifty by using some leftover cabinets. I have a 201X in a 200X cabinet. You can see where 201 sticker was glued over the 200.
Eico 232 VTVM Schematic
There are currently 9031 online users. [Complete List]
» 1 Member(s) | 9030 Guest(s)
