Threads: 49
City: Allendale, MI
Threads: 573
Fairly clean.
With the sole exception of the filter block cleaning out, 20 is a walk in the park.
Threads: 49
City: Allendale, MI
Yes, a simple TRF radio. I've cleaned out those filter blocks before and not a horribly difficult job. I like the fact that the PT uses a terminal block on the PT. I don't have to disturb the wires going into the PT. Some of the other wires connected to the PT are quite crispy. The rest of the wire in the radio appears to be "push back" wire without rubber inside. I may just leave it all. I typically like to replace all wire, but maybe not this time.
(This post was last modified: 12-14-2020, 11:06 PM by rfeenstra.)
Threads: 49
City: Allendale, MI
Oops! Bumped the dial while handling the chassis. It shattered! Very brittle. I'll have to order a new one from Radio Daze.
Threads: 54
The grille in that set is not in bad shape compared to many of those 20s, repairing the veneer should be fairly easy as it's chipped out parallel to the grain. So a straight sided patch, followed by gluing, clamping, and then careful filing, and sanding around the openings, and the patches should be almost invisible, as long as you pick veneer with similar grain, and colour. I'm not sure what species of walnut was used in the front panels of these sets, I think it was French walnut, but Steve could tell you.
Threads: 573
Yikers.
Threads: 156
City: Westland, MI
I've not found the wiring in my model 20 to be an issue, not that it can't be. Maybe I'm just lucky. Take care and BE HEALTHY! Gary
Threads: 49
City: Allendale, MI
I think I'll work on the grille a bit tonight. The are a couple of pieces of the "core" wood that are cracked and loose. Should be easy to glue up. I'm thinking I'll use hide glue as it is easy to remove from places where I don't want it such as where I need to glue veneer later.
It looks like they used glazing to color the edges of the grill. Looks like they slopped it on as it ran down the back side of the grille. Anyone know what they used?
(This post was last modified: 12-15-2020, 08:03 PM by rfeenstra.)
Threads: 49
City: Allendale, MI
did a lot of gluing on the grille. Everything seems pretty sturdy now. Next is to find some matching veneer. The quality of the wood that Philco used in the front panel leaves a bit to be desired. A couple of more laminations in the ply would have helped.
Also started disassembly of Chassis. I had to accomplish something positive rather than just disassembly so I redid the tuning cap.
Before:
After:
Threads: 214
City: Seattle
State, Province, Country: WA
Beautiful- as good as new now!
Any tips for how you clean them up so well?
Threads: 112
City: Medford OR (OR what?)
Be carful polishing the metal. If you remove all of the plating it will look good - for a while.
Fun with chemicals and electricity:
https://www.russoldradios.com/blog/back-...th-5-f-134
Threads: 49
City: Allendale, MI
Russ, plating was put back on!
Threads: 573
I did not do any chemical treatment.
I washed it in a dishwasher, dried it......does not shine. But does not require any chemistry.
Though of course, if this look you achieved is going to hold, it does look great.
Threads: 112
Very good!
Threads: 49
City: Allendale, MI
Unfortunately, I can't do the whole chassis so it will look foreign sitting on top!
Gloritone 27 Radio
I have a model 27 that someone painted the cabinet brown. I've been trying to sell it for awhile but the cabinet paint m...Jim Dutridge — 02:30 PM |
Restoring Philco 96
Joseph
Yeah. The situaction is complicated by me living with my family in NJ while mom is in FL.
Were it not for my ...morzh — 10:55 AM |
Restoring Philco 96
Best of wishes for your mother. I hope she recovers well. My mother struggles with sciatic pain as well, so I am familia...jrblasde — 10:41 AM |
Restoring Philco 96
Well, because I am away, I cannot check it. Hope mom becomes better enough for me to get back.
I think I will be here f...morzh — 10:27 AM |
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM |
Gloritone 27 Radio
Hello john,
That, is the first time I have have seen or heard of that brand and model.
Welcome to the party !!
Sincer...radiorich — 08:08 AM |
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM |
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27:
A little bit of extra t...Eliot Ness — 05:48 AM |
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM |
42-345 Resistors
Great comments.
I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM |
There are currently 1543 online users. [Complete List] » 1 Member(s) | 1542 Guest(s)
