Ground Connection
Dear Friends
This is a very easy one for those who knows the answer. Per the attached pic of a female 3.5 mm terminal, how can I determine which goes to ground? The one that looks cupper or the chromed one?
Thanks
The shell is always the GND. The center is teh signal.
The larger one is ground. The other two are the left and right channels.
Philco 49-1040
