41-680 bol changer
Hello I’ve got a 41-680 with a beam of lite changer 4 wires are coming out of the tone
Arm two come from the sensor to rca jack mounted on terminal strip along with two screw terminals one has black wire with spade lug theses go to the lite there’s no wire from radio to run the lite. I am wondering what voltage the lamp runs at is it filament voltage?
Lamp is good shows resistance.
Forrest.
I think you mean a 41-608?
The lamp is powered from the bottom winding on #9.
You'll need a rf volt meter to measure it.
Part55-Philco 1941 RMS Year Book.pdf (philcoradio.com)
Hello Forrest,
welcome to the wild world of Philco's beam of Light  Icon_lol
I also have a one in my collection too but my model is a single record player and loads through a slot like a car   cd player
Hello,
Thank you terry for the reply yes it is a 41-608 sorry about that, yes I figured it out got the lamp lit and it lasted about 45 seconds and went out. I guess there no longer available I’m going to try building a rectifier off the filament supply to run a #47 bulb
Radiorich I’ve never heard of something like that how old is it?
Might give a #55 lamp a try.
Philco 49-1040
Philco 49-1040
