Paper Capacitors Replacement
Threads: 569
I have been using Mouser for....30 years.
And, no, you do not have to include lead length when shopping for axials.
The radials - yes, they could be leadformed.
Not axials.
And, even if yes and in doubts - the part there almost always has link to the datasheet where you could see everything based on pat number including the lead length, if applicable.
To me personally, Mouser is THE LEAST trickiest of all the places I've been using, and I use Digikey for almost as long, Newark and Allied. Plus some others that I use less.
PS> I am not advocating not using Sal, I am just saying, if you need the caps soon - Mouser is an excellent choice, and then once Sal is back in operation, you could keep ordering from him.
Threads: 569
Just an example of using Mouser:
Let's find an axial 10nF 630V one.
From the Mouser.com page go to "PASSIVE"
Then choose "Capacitors".
Without even specifying the type roll down to the search parameters. Use slider to go to the "Capacitance" column.
Click anywhere in it. Type quick (it allows time between keystrokes but it has to be reasonably fast or else it will think you are typing another value) "0.01 u". The "space" has to be there.
It will take you right to the 0.01 uF value.
Then move to Voltage Rating DC column and pick 600 VDC. Also in "Termination Style" pick "Axial"
Then press "Apply Filters" button.
You will have the list of the available caps.
The cheapest, $0.59 apiece in qty 10 is this
https://www.mouser.com/ProductDetail/Cor...qUd%2FQ%3D
598-103MWR630K
The datasheet also says that the minimum lead length is 35mm (1.4")
Threads: 114
City: Sneedville, TN
Arran, amen about rubber covered wire ! Not just on Philcos either, RCA used it in the late 30s and 40s too. You basically have to re-wire the whole darned set !
Threads: 50
City: Shenandoah,
Just my 2 cents worth but I’ve looked at Mouser a couple of times and it seemed to me to be unnecessarily complicated and involved to find what you need, so many steps to do. Justradios.com or Sals is easy peasy to find what most of us doing antique radios usually need! Now if you need components for modern electronics, Mouser will probably be a better source.
Ron
Bendix 0626. RCA 8BX5. RCA T64
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
Threads: 569
Mouser is a catalog with a few hundreds of thousands of components.
It requires a more sophisticated engine to search.
Just the capacitors are 16 basic types, and then categories and variation.
A website selling caps for hobbyists like us needs pretty much one voltage rating and one type of axials and then some electrolytics. It does not require any search engine whatsoever. A list will do.
And yes, Mouser sells more expensive parts. We rely on Sal's experience to sell us something that he found that is good enough but not a brand. Mouser simply cannot do that (although they do sell Lelon, but then it is a brand. An accursed one at that but nevertheless  )
Threads: 268
+1 Ron
I was looking a a rather simple part put in the values and went down the list of "filters" and applied them and came up with like 5000 hits! 4950 had NOTHING to do with what I was looking for. It was like looking for 6" speaker cones on epay. Life is short forget them. Too many other sources that easier to order from and less expensive.
Have used the place up in CA before many yrs ago. I think with them you had the print their order form fill it out and mail it to them. They in return would give you a total and ship if all was amenable. The only reason I used them at the time was I need some 6000v caps for a electrostatic deflection TV set I was working on and they were the only source granted this was maybe 20yrs ago or more.
For the last number of years I've been using Sal and have been very happy! In some instances he's not the fastest, might take a week or so to get your product but have never had any mix ups or problems. I generally order in lots 25 to 50 pcs per value so it helps me keep a better eye on what I'm getting low on and can put it on the order list.
I'm not in a hurry as I don't do service work for customers generally so a week is not that a big deal to get a set done. Not under the gun as some are. Do sell sets on occasion so I don't have to keep tripping over them.
(This post was last modified: 01-29-2021, 10:47 AM by Radioroslyn.)
Threads: 2
City: Coeur D'Alene
State, Province, Country: ID
Just sent in my order to Sal. He didn't get my emails so I tried another email that was on his site and he was able to get it.
Threads: 2
City: Coeur D'Alene
Threads: 91
City: Jonesboro
State, Province, Country: AR
There used to be scans of the labels somewhere on the Philco website. Things have been moved around, so I'm not sure where they are now.
I'll keep looking. Until then, here's a helpful link from the Philco Library.
DIY Labels
EDIT: Here it is.
1941 Station tabs
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 268
I looked around for them and couldn't find them. Where were they?
They used to be in downloadable files but a lot of that data has been
shifted over to the Library. Sometime I have trouble figuring out what
category certain items have been listed under.
Threads: 569
Give Chick Paci a call or an email. He makes good labels.
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
There are currently 4001 online users. [Complete List] » 1 Member(s) | 4000 Guest(s)
