Rebuilding Model 65 condenser block, steel case
Question on this. I've got the block out; how do I get it apart? It looks like the caps are held in with a wax or glue. I've gotten the base plate apart from the rest of the case, but I need to either get the caps released from the case (heating?) or cut the wires and dig them out mechanically.
Advice?
I just did my 87 and 77. What I did was holding the canister wearing a heavy welders glove, heated it all around with a high temp heat gun and shook it up and down. After a couple of minutes, the condenser block fell out. I cleaned the case painted it w/glossy black lacquer, soldered the new caps. to lower inside plate portion, and put it back together. No body will be the wiser. Good luck.
I use a heat-gun in similar fashion to removing the guts from bakelite block caps.
How To Rebuild Philco Bakelite Blocks
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8528 online users. [Complete List]
» 2 Member(s) | 8526 Guest(s)
