Testing Model 20 tubes - Hickok 539A
I dug out my old Hickok 539A tube tester to check tubes on the Philco model 20 that I am restoring. There were settings for 80 rectifier, but no settings on the chart for 27's, 24's, or 71A's. Does anyone happen to have these settings available for this tester?
Thanx.
Well as a matter of fact I do.
http://www.stevenjohnson.com/hickok/index.html
Enjoy
Thanks, Terry
Do you know if data from other models still match up to the 539A? The suppliment seemed to only contain addition to newer tubes. I did find "obsolete" data under the Model 752 and the setting titles seem to correspond.
Thanks again
Randy
Not sure. You could drop Steve a note and see what he has to say.
I have this listing for Padgett's website on hickok tube testers. Give it a try.
http://6007.us/
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 5314 online users. [Complete List]
» 3 Member(s) | 5311 Guest(s)
