Philco beginners site circa 2012
Was just roaming the net and saw this for the 1st time: http://www.walkingitaly.com/radio/crema/...philco.pdf Thought the information was noteworthy and not too over whelming for someone who is starting out. It's biggest shortcoming is that it was never completed. The table of contents lists a number of thing that aren't there and the links don't work. But the electronic service section and the limited history is pretty good.
Interesting, someone saved it as a PDF file.
The entire site is archived at ARF's server, with working links:
https://www.antiqueradios.com/philcorestorer/index.html
Eico 232 VTVM Schematic
