Threads: 54
Mike;
The changer is definitely a replacement, the originals were 78 rpm only, and had a slicer on the corner like many 78 changers did. I think the unit in there is an older V.M unit, can't tell you the model. What does the printing say on the underside?
+1 what Arran said.
Threads: 5
City: Newark, Ohio
That changer was built by VM on the 46th week of 1958.
It's model number ( 1210B151 ) indicates it's from VM's 1200 series.
Threads: 569
Thanks Arrsna, Ron, Ed - that is a big help.
I was wondering why it is "hotwired". The capacitor in series......I wonder why. The wire is from the chassis so short of the radio's transformer leakage and someone getting zapped.....or the RF filter C75 leakage, they decided to remove the wire and replace it with a cap; 0.01uF will limit the current to a safe, if still appreciable, sensation. I think I will start with direct connection as I have replaced C75 with two Y-rated caps as I always do.
So I need to find the service info on that VM record.
The rubber wheel idler feels hard. It is smooth and not chipped around, but no longer feels rubbery.
This radio had several problems that would stop it fro working so no wonder people gave up on it. Two tubes with shorts, one resistor which is a load, fully open......
The phono input works - when touched it produces hum.
Again, it seems hand-wired, a pluggable old stype RCA jack.
So the reason the turntable is not moving out is, it probably did not fit the old shelf so the shelf was either replaced, or...
I wonder why they decided to immobilize it.
Threads: 569
Took off the back bearing holder of the motor, lubed it, and put some lube in the front holder. Did not take it off - this requires taking the motor off and it is a bit cumbersome.
The motor runs fine; a bit of a hum does not seem to be loud.
Took of the idler. It is a double idler; the wider bottom one goes to contact the motor stepped shaft, and the narrow top one runs against the platter. The top is still rubbery but the bottom is hard.
Need to find a new one or try to ask Gary if he restores them. After all it is a V-M and this is what he does.
Also Ed Morris seems to like restoring these.
Threads: 569
Seems like Gary has everything I need.
The idler, the motor mounting grommets, the needles.
I probably will buy the service/lube guide too.
Threads: 569
The diagnostics stand
Threads: 268
Clever!!
Threads: 55
City: Lexington, KY
Yes, very clever
Lay a piece of mirrored tile on the bottom and you might not have to stoop down as much to view the operation.
Threads: 569
Johm, I would but ain't got no mirrors at home to spare.
Threads: 50
City: Shenandoah,
Hey Mike, My dad had a TV/Radio repair business in the 50s early 60s and this was a changer cradle he had. It is fully adjustable for width and can hold a record changer at different angles. The name on the side is GC, General Cement! Might be a good tool for anyone who does a lot of service on record players if one could be located, maybe eBay!
Ron
Bendix 0626. RCA 8BX5. RCA T64
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
Threads: 416
City: Boston
In High School metal shop that would have been a good project!
Threads: 569
Ron
Great tool, yes.
I am not sure I understand how the TT is secured to it...or maybe I do, so the left side wing nut clamps the left lip of TT chassis between the two pieces and the right does the same to the right lip. Got it.
Yeah......nice stand.
Threads: 50
City: Shenandoah,
Yeah you get the idea. The clamps are all just hanging loose in that picture but you can see there are green felt pads on each end that you orient them into the right position and tighten the wing nuts with the felt part on the top surface of the changer to protect from maring it!
Ron
AK 35 Philco 46-350
Threads: 55
City: Lexington, KY
Hey Ron, you got all kinds of goodies from your dad! First the Trol Master and now this.... I've had a search going on eBay for a Trol Master ever since mike found his, but so far no hits.
Sorry for the interruption, we now return to our regularly scheduled topic.....
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
