37-690 Alignment
I hope to perform an alignment on my 37-690 this weekend, and could use some advise on how to best do this.
When I was aligning my 38-116, I found several points where I could hear a signal from the generator, as I was adjusting the trimmers. This is confusing. How do you know which one is correct? Is it the loudest one, the first one?
Also, any other tips on alignment would be helpful to me. I never really had any training on doing this, and could use some general advise.
Thanks!
Frank.
First, align the IF section. Set your oscillator to the radio's IF frequency, probably 455 kc, and tune the trimmer caps in the IF cans to peak output.
You can use your ears, but all proper manuals will tell you to put an audio signal on the oscillator, and measure the voltage out of the audio section.
We could find 10 different opinions on which IF can to start with, but you'll have to go back and forth one after another, since the cicuits within each transformer interact with one another. With this radio, you MUST set the variable bandwidth to the minimum (counterclockwise?) position. Otherwise, you will not be accurate. The wide bandwidth position broadens the response curve to a flat-top, not a peak. Ideally, we would all have RF wobbulators, which SWEEP the output signal through a 20kc range from 445 to 465 kc, and watch the output on a scope, tuning for for a peaked curve (best selectivity) or a flat-topped hump (best wideband audio). Lacking this, imagine you are looking through the keyhole on a door, down a hallway, into th keyhole on another door, more hallway, another keyhole, etc. You are trying to get them ALL in a line so that a laser beam could pass through the series of holes and shine on a wall at the end. Reduce the output on the oscillator as you get closer and closer to alignment, so the AVC does not make the tuning seem broad.
Once completed with the IF section, set the radio to the AM BC band at about 600 kc, set your oscillator to 600kc if you have a counter to verify with, or if the radio actually picks up stations, set the dial to that stations frequency and on the multi-gang tuning condenser turn the trimmer for the local oscillator section until your oscillator signal (or station selected) is peaked. With most radios the oscillator section has smaller cut plates, but I think the radio in question has all the same size and has trimmers and padders which complicates the issue. You may have to refer to docementation to verify which is which. After you have the signal of interest at the correct setting of the dial, you must then peak the trimmers on the other 2 (RF) sections for maximum output.
Now pick a frequency at the upper end of the dial and find which trimmers
adjust the upper end. They are different from those for the low end.
Repeat the procedure at the upper end of the dial. Now go back and recheck and/or adjust the lower end of the dial. This is a general simplification, as this radio has MANY trimmers and padders, and they all interact with one another, from one band to other bands, and you can really throw things way off if you just start twisting randomly. You really should try to follow Philco's recommended order. If someone hasn't already "tightened those loose screws" you shouldn't have to move them much. Accquire or make a non-metal hex driver to adjust with, or prepare to go nutty fighting the detuning effects of a metal tool.
Most radio manufacturers recommend starting on the lowest frequency band, align that, the next higher, and so forth. Finally, check the midpoint of each band with an oscillator and frequency counter to see if the dial scale error is acceptable. There is normally some error at the 25% and 75% tuning mesh positions, one above, one below. But if you've done the job right, the dialscale error should be nil at 920 kc or so on the BC band.
Having not done this before, expect some frustration. If you can, practice on a much simpler radio first, to get feel for how it all works.
If the radio is out of the ballpark, STOP and get the factory documementation and READ it 5 times before you get deeper into a hole.
Best of luck..
This is a complicated set to align. It must be done is the correct order and steps given in the service info which has 4-6 steps for each freq. band, in correct order, controls set to specific settings, etc.
The set also has Magnetic Tuning (AFC - automatic freq control)adjustments which are also done after full alignment.
Mag Tuning is off during initial aligning steps and is part of the Auto Dial tuning mechanism on your set.
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
42-345 Resistors
Great comments. I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM
