Threads: 34
City: Spring Lake MI
Hi, just started looking this radio over I have all the caps but one, it is the 2uf 50V in section 3, I-F detector and A-V-C circuits.
I do have a 4.7 400V, would that be a bit much for this.
Jim
Spring Lake MI
Threads: 114
City: Sneedville, TN
I think I would order a 2MFD condenser, maybe 100V. Looking at how that one is used, I am not sure if the higher capacity might screw something up, though probably not. Besides, the 4.7MFD 400V condenser is going to be a lot bigger than what you need there size wise.
Threads: 34
thank you
Jim
Spring Lake MI
Threads: 34
This radio has a current limiting resistor, a 25 ohm part # 33-1334-5 what is the wattage. It is flex type resistor.
Jim
Spring Lake MI
Threads: 114
Look in the library section from the home page of this website. There in the 1957 parts and accessories catalog, on page 28, you will find the listing for part 33-1334-5. The 33-1334 part indicates a flexible wire wound, fiberglass covered resistor, the last 5 indicates which one, in this case, a 25 ohm 2 watt resistor, with a body length of 1 inch, which in 1957 sold for 35 cents. if you are replacing it with a more modern type, you will want to go with a 5 watt wire wound, I would say....
https://philcoradio.com/library/download...dition.pdf
Threads: 34
Thanks Mike, I now have some on order.
Jim
Spring Lake MI
Threads: 34
Ordered a new volume control to replace the bad one.
I have a question, if I replace the 117Z3 rectifier tubes (2) with a 1N4007 diode & resistor, will I have to strap pin 3&4 the heater pins. It looks to this may not be necessary because they are not in the series with the other tube heaters?
What do you think?
Jim
Spring Lake MI
Threads: 268
I wouldn't but it would be real exciting if you did!!!
If you connect 3 and 4 together on the 117Z3 you'll be shorting the ac line out.
Threads: 27
City: Tehachapi. California
I think you answered your own question. The filaments are not needed for 1n4007 diodes. Don't forget that the silicone diodes only have a .7volt drop across them. Your voltages will be higher than the tubes.
[Image: http://philcoradio.com/phorum/images/smi...on_eek.gif] Chris
Threads: 34
WOW I blew that one thanks.
Jim
Spring Lake MI
Threads: 34
How would you place the diodes and resistors to replace the 117Z3 rectifier.
I have read that the diode would go from pin 5 to 6 band toward pin 6. Would that be true for both of these.
Jim
Spring Lake MI
Threads: 44
City: Roseville, MN
That's correct, and you might want to connect a dropping resistor between pin 6 of the lower rectifier and C104A to drop the B+ to 210V. Probably somewhere between 47 and 100 ohms, 1 watt. If you do this you'll reduce the heat to almost zero and that's a good thing!
Threads: 34
Thanks RodB
Jim
Spring Lake MI
Threads: 34
Got it to work on AM had to repair the 1st AM IF transformer, now I found that the FM OSC trimmer (C400C) is flaky, just touching it, it will change. The tube that it is in is broke, don't know if it glass or plastic. Has anyone repaired one of these.
Jim
Spring Lake MI
Threads: 27
I am pretty sure it's glass. You might try some of the clay type epoxy. wrap it around and stabilize it. Otherwise you need to replace it. It's a trimmer cap.
Make sure the epoxy does not have metal in it.
I would have it running to watch to see how much the epoxy affects the tuning.
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
